Having Trouble Starting
Old May 24, 2010 | 05:18 PM
Champs32's Avatar
Post Having Trouble Starting
So my 93 sol (mini motor) (block is built everything else is stock) Im having trouble starting it. It turns over but doesnt seem to want to fire. I have replaces the spark plugs w/in the past 8 months or so and i replaced the dizzy cap and button along w/ wires. Could it be the dizzy? Maybe timing is off? Or injectors? I replaced the fuel filter roughly a year ago give or take a few months. I need my car for work but I cant rely on it. Can anyone give some advice?
BTW... It always starts...... EVENTUALLY! But its been worse lately
Old May 24, 2010 | 05:49 PM
Champs32's Avatar
Default Re: Having Trouble Starting
Anyone?
Old May 24, 2010 | 06:22 PM
Hondatherdm's Avatar
hook up fuel pressure gauge get the car started, turn it off and see how fast pressure drops
Old May 24, 2010 | 07:00 PM
Champs32's Avatar
If it drops fast, is it the filter
Former User's Avatar
Listen for whether the fuel pump primes for 2 seconds when the key is turned to ON(II).
Check for spark at the plugs.
Any CEL codes?
Old May 24, 2010 | 07:04 PM
I disagree. That means its fpr or check valve. Fuel filter has nothing to do with this except when you go to accel
Old May 24, 2010 | 08:15 PM
Champs32's Avatar
No codes. It does prime. Sparks fine. I dont think its the any valves. Id hear that more than likely. Fpr is something i didnt think about. Before I check that is there anything else it could be?
Old May 24, 2010 | 08:36 PM
If spark is bright white, then check the mechanical timing. The timing belt may have skipped a tooth or two.
Old May 24, 2010 | 08:50 PM
Champs32's Avatar
It may have possibly skipped a tooth as well. The crank pulley bolt came loose the other day
Old May 24, 2010 | 09:16 PM
96DelSol's Avatar
Things are leading towards your timing since you have spark and fuel.
Old May 25, 2010 | 06:14 AM
Champs32's Avatar
Alright. Thanks guys. I will let you know how it goes
csckwade
Dec 28, 2012 11:01 AM
jason ontiveros
Feb 12, 2011 11:42 AM
BUILTandBOOSTED
Jun 26, 2008 08:04 AM
Lonny
Apr 13, 2003 01:12 PM
Tij
Sep 2, 2002 04:49 PM
