99 civic starting issues
Old May 24, 2010 | 03:21 PM
DevilJin6six6's Avatar
Default 99 civic starting issues
I did a quick search and found someone with a similar issue, but no resolution so i figured i would post and see what Ht had to say about it.
I get in the car, put the key in the ignition and turn it to ACC, all the lights come on and the stereo works, i depress the clutch and everything stays as it was. when i try to crank the car over i hear a single click and everything goes dead. EVERYTHING. no radio, no headlights, nothing. It stays that way for an indeteminate amount of time, and every once in awhile it will let me repeat the cycle. I have tried replacing the battery and checking the grounds already. Any ideas?
Old May 24, 2010 | 06:29 PM
Hondatherdm's Avatar
Default Re: 99 civic starting issues
Try good known starter
Old May 24, 2010 | 06:39 PM
Former User's Avatar
The headlights don't get power through the ignition switch. This points to a bad battery ground wire or bad battery terminals. Inspect, clean, and tighten them.
Old May 24, 2010 | 06:41 PM
D16SiHatch's Avatar
i'm still thinking ground issue. lights, accesories, etc should not shut off like that
edit: damn, beat me to it lol
Old May 25, 2010 | 05:22 PM
any help and all ideas are appreciated, thanks guys. it started raining before i got home from work, so i didnt get to work on anything today
Old May 25, 2010 | 06:12 PM
Mad-Mike's Avatar
My civic did the same thing before, what I did was pressed down on all the fuses under the hood to make sure they are all plugged in. And I moved around the wires connected to the battery. It started right up after. Could be a loose fuse or battery cable.
stella88
Nov 15, 2018 09:56 PM
Goobergobbler
19
Jul 27, 2016 04:14 PM
lostinmiself
26
Jul 11, 2010 06:39 PM
nedjinski
Sep 7, 2007 03:04 PM
immrtaltchnq
Aug 9, 2006 09:06 PM
