Touched distributor to battery..question
Old May 24, 2010 | 01:17 PM
jeffhoe's Avatar
Default Touched distributor to battery..question
I went to install my dizzy and touched my socket on the positive battery terminal. Im not sure if this is related, but long story short i just got my ecu back after giving it to a mechanic as collateral for a week, and now i have a code 16 and no start. Could this be from touching the dizzy to battery?
Old May 24, 2010 | 03:53 PM
TeamRedline89Hatch's Avatar
Default Re: Touched distributor to battery..question
Code 16 is the fuel system. You sure you got the right ECU back?
Old May 24, 2010 | 05:16 PM
jeffhoe's Avatar
Its a p28.. not sure if its mine tho
Old May 24, 2010 | 10:02 PM
jeffhoe's Avatar
bump.. anybody???
Old May 24, 2010 | 10:10 PM
StayKrafty's Avatar
Never had the code before? Did the dizzy touch the battery? Or just your socket? And FYI, when working on a car; especially electronics, disconnect the ground from the battery.
Old May 24, 2010 | 10:15 PM
jeffhoe's Avatar
just the socket touched the battery but it was on the dizzy bolt and sparked and left a nice spot in the ratchet. The main relay clicks, so I assume that cant be the problem. The code wasnt there before. I also installed ac while i didnt have my ecu. Maybe thats messing it up?
Old May 24, 2010 | 10:18 PM
StayKrafty's Avatar
Could be in the wiring maybe. Have you checked the fuse? Whats it doing when you try and turn it over?
Old May 24, 2010 | 10:33 PM
jeffhoe's Avatar
fuses are all good. car just cranks im gonna check for spark tomm
Old May 24, 2010 | 10:46 PM
StayKrafty's Avatar
Hmm, definitely sounds like your problem is in the dizzy. Good luck.
Old May 25, 2010 | 03:39 PM
jeffhoe's Avatar
Problem was the main relay. Thanks for the help.
pitti
Jan 9, 2017 04:47 PM
Tom's hybrid
Honda Civic (2001 - 2005)
Jan 7, 2013 04:02 PM
daver321
Dec 25, 2008 06:39 AM
zak88lx
Oct 5, 2005 10:55 AM
MidwestSi
Oct 5, 2004 09:54 AM
