drivetrain clunking during braking and when going over bumps
Old May 24, 2010 | 10:43 AM
tealchief's Avatar
Default drivetrain clunking during braking and when going over bumps
as the topic states i am experiencing a clunking noise when ever i brake over 35 mph. i am also getting a clunking noise from the same side of the car when ever i go over a bump or manhole. it is very annoying, i am going on a 300 mile drive this weekend and i would really like to fix this when i get back. it sounds like a metal on metal noise and the vibration from the brakes gets worse when i brake harder, it is also the worst from 45-35 mph. i am suspecting lower ball joint, some weird brake problem, wheel bearing? blown shock?
repairs made: inner tie rod, new axle, new rims(should of used the money to fix this problem i know!!)can some one please help a brother out..
Old May 24, 2010 | 11:00 AM
tealchief's Avatar
Default Re: drivetrain clunking during braking and when going over bumps
ttt
Old May 24, 2010 | 11:09 AM
tealchief's Avatar
the car also pulls to the right(affected side) , i've also gotten 2 alignments.
Old May 24, 2010 | 11:24 AM
Ef8crxsi4u2nv's Avatar
It could be you got a warped rotor on the right side. That would cause serious vibrations and shaking, Also could be a combo of that and blown shocks.
Old May 24, 2010 | 03:10 PM
TheJGB3's Avatar
Check the balljoints and control arm bushings.
d16vteceg
Aug 12, 2006 10:09 AM
deboda954
Jun 21, 2006 09:21 AM
Spence
Suspension & Brakes
Jul 18, 2005 03:38 PM
EK99hatch
Nov 14, 2004 09:30 PM
navin
Oct 7, 2003 07:42 PM
