How to check Tire Tread Wear ?
hey how do u check if a tire still has enough tread on it ?? Something about taking a penney or dime and seeing if the tread is above the head ?/
i think you put a penny upside down. or head first. and see if you can see his head..if you cant your ok. if you see lincolns head your not in good shape.. i am not 100 percent on that though
On the inside groove of the tire(center) there are pieces that run across the center. Those are there to judge the tire wear. Turn your wheel so you can see the center of the tire and look along the center of the groove until you find that. When your tire is worn even with that, you are at the legal limit of tire wear and must replace them.
email me if you need a picture or something
Use a penny, put it so Abe's head is in towards the tire. If Abes head is above the tread, then you need new tires.
