Need help checking my cels.....
Old May 23, 2010 | 08:40 PM
love_ek9's's Avatar
Icon2 Need help checking my cels.....
Ok i have a 91 dx hatch with an obd0 to obd1 conversion harness i know where and how to check the codes i just cant get them to flash on the dash please help i need to fix these things and get my vtec working again....
Old May 23, 2010 | 09:02 PM
D16SiHatch's Avatar
Default Re: Need help checking my cels.....
did you try grounding out the wire at D4? that should make your ecu start spittin out codes.
Old May 23, 2010 | 11:22 PM
love_ek9's's Avatar
I've never heard of doing that before is it covered in a how to and if so do you have a link
Old May 24, 2010 | 09:45 AM
D16SiHatch's Avatar
well first off what have you tried to make it give up the goods?
your car should have a small 2 pin connector near the blower motor by the passenger side kick panel. if you jump those 2 wires it will make the cel flash out the codes. if you cant find it for some reason then just run run a temporary wire from a ground to the spot D4 on the ecu.
http://www.jspecauto.com/images/sce/eg-pin.gif
Old May 24, 2010 | 01:17 PM
love_ek9's's Avatar
Yea i know where the 2 pin connector is down by the blower motor i've tried that and couldn't get it to jump anything on the dash? so i guess i have to go straight to the problem and find the wires that do make it flash coming from the ecu...
Old May 25, 2010 | 11:56 AM
love_ek9's's Avatar
bump tt
Old May 25, 2010 | 09:11 PM
love_ek9's's Avatar
bump tt
Alen1293
Jan 22, 2012 05:24 PM
19992civichatch
Jun 24, 2007 06:39 AM
Tw1n Turb0 Z
Feb 11, 2007 11:08 PM
Tw1n Turb0 Z
Oct 9, 2006 06:18 PM
Modern91Hatch
Jul 27, 2005 12:44 PM
