window keeps going off track such a pita
it seems to me that like once a week my window comes off track and wont go more then 1/4 way up. i took my panel off and unscrewed the track several times and got it back on and put it back together, cant seem to see any issues with it anyone have this problem?
I had a regulator problem, then I changed it, but my window channel was still getting caught in the glass so I had to slowly put the window in as I moved the channel around it then if it was fine if that makes sense. So it could be a combo of both, but I'd watch the sides of the window first.
having same issue my window falls off the track everytime i roll it down. it feels like you got to crank it hard. took panel off and when i pull the window off one the sliding fitting that go on the horizontal track pops off when i force it too much. i think its the sides so was wondering how you lubed them up and what you use to so. if you got pictures that will be helpfull as well. need to fix fast its getting hot here and tired of only having my pasanger window open only.
on one of egs i had a similiar problem. their was an adjustment nut that was accesable once the panel was removed. if the nut is not in the proper position then the window will pop off track. you will see a few dashes on the door next to the bolt that is threaded into the regulator. the hole in the door will be elongated.
adam jeffery
adam jeffery
Nighthawk7thGen
Honda Civic (2001 - 2005)
Sep 17, 2008 08:03 AM
Markb16a
24
Oct 8, 2007 08:31 PM
aZnjCC
11
Aug 16, 2004 07:51 PM
