Car is rev limiting at 3.5k
Old May 23, 2010 | 03:15 PM
UnciviLcivic's Avatar
Default Car is rev limiting at 3.5k
Just bought this car from this guy 98 Honda civic, he told me that he had the motor replaced but when I inspected it everything was hooked up good but the motor in the car was a 92 d16z6 and the check engine light was on. I took it up to the Firestone where my boy worked and used the reader for the codes , looks like a speed fluctuation sensor was apparently missing and I can see it unplugged now after doing some research it was to my understanding unless I got it wrong that the 96 and up do not had this? After checking all the wire harness I found out a few plugs were unplugged that were throwing originally other codes but they cleared and now. The only thing left is the speed fluctuation sensor plug and no where to plug it. Now after driving the car for a few hours I have the problem of the car rev limiting at 3.5k. It's an on and off problem but i could let it sit for a day or so and it will start up just fine, and then I drive it again and the same problem , I'm out of ideas ????
Old May 24, 2010 | 04:54 AM
Default Re: Car is rev limiting at 3.5k
No one has had this issue?
Old May 24, 2010 | 07:54 AM
shoklid's Avatar
check your ignitor or possibly cracked ur dizzy
Old May 24, 2010 | 08:26 AM
Red_Army's Avatar
this happened to my friend in his GSR. just the rev limiter. try swappin out ECU with a new one. not saying it'll fix your but it fixed his.
good ol fashion limp mode.
Old May 24, 2010 | 10:21 AM
apexi_rsx's Avatar
if it has a z6 motor in a 98 civic with a 98 civic ecu or y8. you dont have the knock sensor, Crank sensor hooked either. you would have to get a lower timing gear from a y7 or y7 and use the y8 oil pump/ pick up and oil pan. it can cause this to happen...96-00 had the crank sensor by the lower timing belt not in the dizzy like 92-95.... or you will have to get conversion harness and run a p28
Old May 24, 2010 | 12:03 PM
DOHCterJEREMYb's Avatar
i suggest getting a getting the conversion harness and running the p28 ecu
Old May 24, 2010 | 02:46 PM
That sucks , any idea where to get the harness at or the ECu ?
Old May 24, 2010 | 04:55 PM
apexi_rsx's Avatar
you need a conversion harness for a obd2a-obd1 and a p28 ecu both could be found on ebay. just make sure the ecu is a 5spd
Old May 25, 2010 | 11:33 AM
Does it matter if my car is a automatic and will a b16 dizzy work on a d16 ? I found oil in the cap so I figure there is some kind of crack or something
Old May 25, 2010 | 12:14 PM
mikej94civex's Avatar
i did, but my rev limit was 5k not 3,500....replace ur dizzy, check ur timing and get a new p28 to be safe
ebay, or local person
Old May 25, 2010 | 07:35 PM
Thanks for all the help guys . I got it fixed got a b16 dizzy for 40 bucks and swapped the internals all but the shaft and everything ran like a champ just have to get that looping idle issue fixed and the speed fluctuation sensor fixed and I can pass inspection YEsssss!
Old May 30, 2010 | 05:04 PM
baloonazar's Avatar
good deal
sinster185
Sep 4, 2015 12:35 PM
mystic-s
Feb 19, 2008 05:06 PM
b16acrxer
Aug 26, 2004 08:00 AM
Qwikrex
Apr 8, 2003 08:35 AM
_VTI-R_
Mar 12, 2003 02:50 PM
