Rear right wheel shaking @ 30mph+? Civic RT4WD!
Old May 23, 2010 | 03:07 PM
trooper0641's Avatar
Default Rear right wheel shaking @ 30mph+? Civic RT4WD!
Car: 91' Civic Wagon RT4WD
Ok long story short.. on 4wd mode it the "right rear wheel" shakes @ 30mph+. But when I switch it back to 2wd mode and drive it 30mph plus, it doesn't. Obviously it has something to do with the rear diff/axles spinning causing the "RIGHT REAR WHEEL" to shake. Anybody else have ever encounter this type of problem with their RT4WD?
Old May 23, 2010 | 11:32 PM
Default Re: Rear right wheel shaking @ 30mph+? Civic RT4WD!
BUMP!~
Old May 24, 2010 | 08:23 AM
88hybrid's Avatar
leave it in 2wd unless ur in the mud or snow. the awd doesn't work like other systems. also try hondacivicwagon.com for more answers
Old May 24, 2010 | 08:41 AM
ef-hatchcrap's Avatar
bad axel in the rear. Just a guess
Old May 24, 2010 | 09:50 AM
baller status's Avatar
Try rotating the wheel to the front and see if the problem goes with it.
Next try jacking up the wheel, grip it side to side, and try to rock it. It should be solid. If it wiggles, look around at the suspension and try to find where the play is coming from. It may be the wheel bearing which is inside the hub. Also try rocking from top to bottom.
Old May 24, 2010 | 12:16 PM
scottmog's Avatar
maybe!
Old May 24, 2010 | 01:45 PM
bump for some more suggestions/advice! Thanks for all your input guys! I'll look into it..
Old May 24, 2010 | 03:22 PM
MOMA HELP!!!!
Old May 24, 2010 | 08:19 PM
d21f23f2f
Old May 25, 2010 | 09:06 AM
worn'ed out mounts thats holding the rear diff possibly?? bump!
Old May 25, 2010 | 12:10 PM
sh!ft's Avatar
Who the fack changed my title?!
or bearings/mud in the inner tire area
Old Jun 1, 2010 | 07:00 AM
ralli-rex's Avatar
try getting the wheel re-balanced, being off by 50oz can cause a pretty big problem. if that doesnt work then do as others have suggested and shake your wheel, if it wobbles bad then ball joint(when shaking extend your arms and lock them, then move you arms forward and backward). Lastly if that doesnt work then its your axel adn you will have to replace it, goodluck.
tommy boy2
May 9, 2018 02:53 PM
usadtITR
May 8, 2010 01:41 PM
tshuajzoo559
Aug 30, 2007 02:00 PM
91integraLSVTEC
Feb 12, 2004 07:56 AM
