Suspension & Brakes Theory, alignment, spring rates....
trailing arm bushings
Old May 23, 2010 | 12:54 PM
efyou999's Avatar
Default trailing arm bushings
im trying to install trailing arm bushings for a rear disc swap and i cant get the new ones in. got a big *** hammer and they still aint going in. any help please.
Old May 24, 2010 | 06:11 AM
phunhaus's Avatar
Default Re: trailing arm bushings
Use the "trailing arm bushing" tool or bring the arm to a shop with a press. A big hammer gets the old one out, but not the new one in.
Old May 24, 2010 | 08:27 PM
FlewByU352's Avatar
as crazy as this sounds I got m energy suspension bushings in using this method. Take you trailing arm and put it on a jack. Lube the sleeve up and the bushing generously and set it on there. Then put the jack under a vehicle high enough for it to clear the trailing arm and start jacking it up. Mine popped in there using that method.
Old May 25, 2010 | 09:50 AM
hybridmiklo's Avatar
I put them in this way as well. I used a block of wood so that it would evenly place itself.
Old May 25, 2010 | 09:55 AM
meb58's Avatar
Keep in mind that most bushing bores are tapered...bushings get pressed out one way and get pressed back in in the reverse direction. This is true with all honda bores. When bushings are pressed back in the narrow portion of the bore expands and the friction or keying is what helps hold the busing in place.
Old May 26, 2010 | 09:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The LCA bushings are NOT tapered. I'm pretty sure the RTA bushing is the only one that is. I can check my old bushings with a micrometer later on.
Old May 26, 2010 | 10:47 AM
1.5Slowmatic's Avatar
put the bushing in a freezer. worked for me.
Old May 26, 2010 | 11:31 AM
phunhaus's Avatar
The rear compensator (toe) arms are as well. But to my memory those are the only ones. All the UCA and LCA are not tapered.
Old May 26, 2010 | 12:56 PM
98civdx's Avatar
Master Detailer
same here.
Old May 26, 2010 | 10:09 PM
BiG ChOr!Zo's Avatar
http://www.youtube.com/watch?v=hPTDzrxqoOo
Old May 28, 2010 | 09:12 AM
EpHatchy's Avatar
thats how i did mine big hammer and cement steps outside my back door..
PatrickGSR94
Suspension & Brakes
44
Jun 13, 2013 03:28 PM
marcsed6
11
Dec 27, 2009 07:02 PM
aimbot
Jan 4, 2008 04:02 AM
chatham
May 20, 2006 10:18 PM
Jays91DXhatch
Apr 27, 2005 08:19 PM
