Recent Work (Non Honda)
Old May 23, 2010 | 04:20 AM
redline6k's Avatar
Default Recent Work (Non Honda)
This is a manifold and o2 housing I built for my dsm. I'm running a HX40 and 2 Tial MVS 38mm wastegates.
Old May 23, 2010 | 09:07 AM
Jaker's Avatar
Default Re: Recent Work (Non Honda)
Tell me about your pie cuts. What angle did you use? I'm going to do it with my mitre saw with a cut off blade. I've been cutting 3" stainless tubing quite successfully for the last little while that way. Also, was it cut - fit - cut - fit, etc... or did you just cut a bunch of pie cuts and then piece them together to get the fit you were looking for?
Old May 23, 2010 | 09:13 AM
RickyLee53's Avatar
Nice work, them Pi's are going to be a PITA to weld. Why didn't you just use normal bends?
Suppose they look JDM though.
Old May 23, 2010 | 09:26 AM
drift2004's Avatar
because it's jdm!!!!
Old May 23, 2010 | 10:02 AM
redline6k's Avatar
I used a 5.5 degree angle took about 8 cut pieces to make a 90* angle.
I needed a real tight radius bend. A 3" 90* bend with a 2.5 CLR and I couldn't find any.
Old May 23, 2010 | 10:51 AM
weiRtech's Avatar
OG Fabricator
8*5.5 only comes out to 44 degrees. either i'm retarded, or they aren't 5.5, maybe one side, but not inclusive.
Old May 23, 2010 | 11:05 AM
Jaker's Avatar
But it's 5.5 degrees per side of the pie piece, so in reality it's 11 degrees per wedge, right?
Old May 23, 2010 | 11:15 AM
redline6k's Avatar
Each side is 5.5 degrees, So it comes out to 11 degrees per pie cut. Times that by 8 and you get 88 degrees.
just.me.ek5
May 11, 2010 09:43 PM
Coke in a Can
Sep 10, 2007 01:25 AM
Reza^
Jun 1, 2006 10:44 PM
LaXcAt
Sep 5, 2005 08:19 PM
dirtyturtle
Aug 6, 2004 02:11 AM
