Powering an ECU away from car
Old May 22, 2010 | 02:34 PM
Sparkles's Avatar
Default Powering an ECU away from car
Hey guys
I was wondering if there was any way to power an ECU away from the car? I don't have a laptop just yet and I would like to install a basemap in my Hondata S300.
Old May 22, 2010 | 02:50 PM
mtber's Avatar
Default Re: Powering an ECU away from car
Yes there is, however there is no point in installing a basemap on an ecu when there is no vehicle to run. I don't understand why you would want to do this.
Old May 23, 2010 | 11:17 PM
Sparkles's Avatar
I do, in fact, have a vehicle to run but no laptop. So the point would be to install a basemap without a laptop. Thanks for all your help
Old May 24, 2010 | 10:19 AM
Relic1's Avatar
ostrich and demon can be programmed without the ECU. (powered via USB)
chips have to be burnt outside the ECU anyway.
why do you need to power the ECU without the car?
the most common reason to power up an ECU on a bench is to verify operation due to a repair.
The best product for this --> http://www.moates.net/product_info.p...roducts_id=198
Old May 24, 2010 | 10:21 AM
HRTuning's Avatar
The S300 isn't powered via USB, only through the ECU.
Best bet is the Engine Sim mentioned above, or manually connecting power and ground (Which any OBD1 pinout chart can give you locations for). If you're not sure what to do with that information, I wouldn't try it yourself.
Old May 24, 2010 | 08:56 PM
mtber's Avatar
You could always get a really long usb cable lol :-)
Just take the car & s300 to a hondata dealer & have them upload a calibration to the ecu for you etc.
98TypeSH
Apr 23, 2004 03:00 PM
acatak
May 12, 2002 05:06 PM
