ls swap then no spark plz help its my daily
so as you can tell i have put a b18a1 in my eg, the car had a d15b7, then we put a z6 in it, after the nitrous, the z6 was a smoking mother, ive just rebuilt this ls motor for the swap, everythings good except i have no spark at the plugs, the dizzy is a reman, from autozone, ive tried another ls dizzy, and ive also tried a single cam dizzy nothing, i get everything else i need except spark it cranks well, it has fuel cause ive already fouled the plugs once and the return line squirts fuel..ive checked the three main grounds, chassis thermostat and valve cover ground, all my fusses look to be good, im so lost on what to do now, if you have any ideas ill def listen this is my daily driver and i need it back plz and thanks in advance
edit also ive checked the plug on the dizzy with two wires, its getting 12 volts on both the blue wire and black and yellow wire if this helps..?
midday bump,
so i have a mechanic friend from national tire an battery he said he would come look at it, i hope and pray to god that he can help me,
im still taking suggestions,
i woulda thought i woulda got at least one decent one but hey cant have everything can we
ProjectEvilEj2
Jan 1, 2009 08:10 AM
Race Egr
Apr 4, 2004 09:32 AM
