D16z6 vs D16y8 exhaust downpipe.
From: fountain inn, sc. where they still rock banjos on porches, usa
well i started this venture on several reasons. first i have a DOHC ZC and i bought a OEM cast upper ZC exhaust mannifold, it didn't come with the lower downpipe. some ppl said get the z6 others said to use the y8.
i've been hacking OEM collectors to remove the restriction of flow.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/my-moose-mod-d16y8-header-2729725/
so here we start here's some specs:
D16z6 downpipe - info - D16y8
43mm(1.69") - flange I.D. - 43mm(1.69")
50mm(1.97") - secondary pipes O.D - 49mm(1.93")
49mm(1.93") - bend choke point - 45mm(1.77")
437.8mm(17") - lenght of secondary pipe - 304.8mm(12")
88.9mm(3.5") - lenghten of V merger - 88.9mm(3.5")
54mm(2.13") - collector O.D. - 54mm(2.13")
152.6mm(6") - collector lenght - 279.4mm(11")
47mm(1.85") - collector I.D. at flange choke - 47mm(1.85")
685.8mm(27") - lenght of total pipe - 685.8mm(27")
now the pics:
the z6 and the y8
the primary bend
bottom view
top view
side view you see the z6 hangs alittle more.
collector view
what the inner restrictor pipe looks like i remove the one in the y8. i will be removing the z6.
so the questions here are very simple:
1. how does two d/p design different yet same length would help the powerband.
2. how does short/long secondary pipes effect your powerband.
3. what is the benifit of a long and short collectors.
and on a final footnote: over the years i've readed ppl asking if a B series down pipe fit on a D series upper primary manifold as a upgrade? the answer is Yes and No. as a plug and play no, but the pipe line up and the flange on the Bseries is a bit wider. so if you reem the downpipe bolt holes by at least a 1/4" on the two outer holes but on the innerside of the flange then yes it'll work. why?
here's the specs of a GS-R downpipe i have that i have to remove the inner pipe.
GS-R B series downpipe
54mm(2.1") - secondary pipes O.D.
51mm(2") - bend choke point
61mm(2.4") - collector O.D.
here's the pic of the flange. on top is a z6 and the bottom flange is a GSR.
i will say this the GS-R dpwnpipe it looks like a z6 downpipe but on steriods. lol.
now the pics:
the z6 and the y8
the primary bend
bottom view
top view
collector view
boostincoupe
Feb 16, 2006 03:21 PM
alphaquake
Jul 14, 2002 04:14 PM
