1999 Honda Accord LX Key Stuck in Ignition HELP!
Hi i have a 1999 Honda Accord LX. The key is stuck in the ignition. Right when you get to the point to push and turn to release the key it wont let you. I hear a click by the glove box area when i turn it to the furthest point. This all started when i shut the car off in drive by mistake. Since then the key will not come out. What can I check to start trouble shooting? Thanks in advance
I would check the park pin switch/circuit. If the system doesn't know the vehicle is actually in Park the key can't be removed from the ignition.
Not the only possiblility but I have encountered this a few times.
had this happen to a 98 Odyssey. just takes patience and alot of jiggling... once you get the key out. spray some wd in the cylinder and insert the key a bunch of times.. DONT TURN IT ON.. just in and out.. get the pins in there all slippery. if it keeps sticking in the future, you will need to get a new key cut.. 98 Odyssey had a new key and hasn't stuck in a year..
mautryodell
Oct 10, 2017 06:21 PM
chupowei
Aug 31, 2007 10:56 AM
