Transmission & Drivetrain Gearboxes, Differentials, Clutches
If The Trans Is Over Filled
Old May 21, 2010 | 06:40 PM
Gabe87CRX's Avatar
Icon6 If The Trans Is Over Filled
in my 87 CRX Si, FI, will that cause it to leak out of the main input shaft?
I finally got my rear main seal, and while they had the trans out, they did a bearing inside the trans and the main input shaft seal...
If my tranny fluid level is too high, will that cause the fluid to leak out of the input shaft seal and down to the bottom of the bell housing?
Old May 22, 2010 | 02:47 PM
Natural Aspirations's Avatar
Default Re: If The Trans Is Over Filled
remove the fill hole bolt and if any runs out it was too full, problem solved
Old May 27, 2010 | 09:18 AM
jlude90's Avatar
Nah, my 100K mile input shaft seal doesn't leak with a full quart of extra fluid in there.
Old May 27, 2010 | 09:59 AM
Gabe87CRX's Avatar
Well... I brought the CRX home.. it dripped all the way home... I went to stop at my job, which requires that you park partly on a curb, I looked under the car, only see the fluid POURING OUT in a constantly drain like motion.
So, Tomorrow were gonna find out... if the axle seals are bad, or if the whole trans needs to be resealed. If it does, I want my money back.
1320london
Feb 1, 2015 10:02 AM
asnydes
Aug 11, 2011 06:26 AM
Slacker93eg
Jun 5, 2011 10:30 PM
RunninEg6
14
Apr 27, 2009 12:44 AM
