Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
accord 2007 4-cyl -hard steering
Old May 21, 2010 | 05:50 PM
hondazzza's Avatar
Default accord 2007 4-cyl -hard steering
following problem appeared just overnight: when starting car in the morning steering is hard, need to use force on the steering wheel to turn when car is at stop or bearly moving. After driving few km, steering appears to be fine. I found no leaks, fluid level is fine, belts tension looks ok.
Anyone can advise?
Old May 22, 2010 | 02:49 PM
diversegsr's Avatar
Default Re: accord 2007 4-cyl -hard steering
air bubble in the line??? possible time to change the p/s fluid
Old May 24, 2010 | 04:42 AM
hondazzza's Avatar
thank you for uour response,
car is only 54000miles, I though about fluid but that should not happen, my previous accord 97 (at 150000miles) steering fluid was never changed.
anyway I will change the fluid
thanks again
Old Jan 6, 2011 | 08:32 AM
Cre0219's Avatar
Did it work? Im having the same problem on a 1990 Honda Accord and Im not sure what to do about it now.
manp
Jun 5, 2017 05:30 PM
Rangers17
Sep 10, 2013 04:39 AM
nobleach
Jan 23, 2013 11:37 AM
BigTwigs1981
Sep 4, 2011 11:27 PM
GunSamir
Jan 6, 2011 08:47 AM
