Anyone ever make a double slip tube like burns ''double slip collectors''
Old May 21, 2010 | 05:29 PM
MidShipCivic's Avatar
Default Anyone ever make a double slip tube like burns ''double slip collectors''
I would like to see the construction of these if anyone has made them.
Old May 22, 2010 | 10:00 PM
HiProfile's Avatar
Default Re: Anyone ever make a double slip tube like burns ''double slip collectors''
Considering it requires a hydraulic pipe expander that's otherwise useless, I doubt it. What else is there to see beyond tech specs of the clearances? They seem to just bolt up tight, and the main seal is from thermal expansion along the full O.D., as the inner tube sees more heat.
Old May 23, 2010 | 04:34 AM
Bailhatch's Avatar
I use single slip connections on exhausts sometimes. They are much lighter and cheaper than V bands and have better clearance. When I weld on mufflers on show cars I usually cut off the expanded inlet and outlet and save them. I just butt two perfectly square ends and weld the expanded part with about a 1/2" of overlap on one side, cut 4 tabs and bolt it together. It doesn't have any flex but is seals pretty nice if you on a budget. That said, I go through a lot of vbands hah
Old May 23, 2010 | 01:56 PM
You know, the question still stand stands, but if no one here has then it can't be helped.
Old May 24, 2010 | 01:37 PM
onefstek's Avatar
From the begining the collector and the header have to be made to be a double slip fit. The distance between the slips of the collector have to be larger to allow for the second slip to fit in between. The double slip has to be welded onto the header pipes before the header is welded onto the flange.
092eg6
Welding / Fabrication
10
Jan 14, 2011 08:21 AM
eflove
31
Aug 16, 2008 04:01 AM
*Boostwerks*
82
Apr 14, 2007 03:10 PM
wrinkles
Sep 15, 2006 04:35 AM
LostCRX
Jun 5, 2005 10:40 PM
