Suspension & Brakes Theory, alignment, spring rates....
endlink problem
Old May 21, 2010 | 02:22 PM
RedSix's Avatar
Default endlink problem
I have a 24mm rear swaybar from asr and the asr subframe brace, I also have skunk2 rear lower control arms. I used the endlinks that came with the rear sway bar kit from ASR, and they are shot they make so much noise its ridiculous, I was wondering if I can use OEM endlinks with that setup, I am not sure if it would work with the lower control arms. This is all on a 2000 ek coupe
Old May 22, 2010 | 12:21 PM
RedSix's Avatar
Default Re: endlink problem
So does anybody know if the oem endlinks work on skunk2 lower control arms???
Old May 22, 2010 | 07:20 PM
Meoshe's Avatar
I hope you know your endlinks are not shot, spherical endlinks are known to click. Stock styled endlinks should work though
Old May 23, 2010 | 02:29 PM
RedSix's Avatar
I know, but they are seized horribly bad, I am just going to go with OEM ones.
Old May 23, 2010 | 03:47 PM
98civdx's Avatar
Master Detailer
Oem should work just fine.
I have sphecials in mine front and rear, and just a slight clunking when one wheel hits a bump and other doesnt at low speeds.
It's just something youll have to deal with if you go with them.
Old May 26, 2010 | 08:00 AM
eflove's Avatar
I had the same thing happen to my asr links. They had a few mm of play. I replaced them with the new Whiteline end links. So far it's quiet. 60mm with 10mm studs it what I got.
http://www.whiteline.com.au/docs/bul...ar%20links.pdf
stevanrk
Oct 1, 2008 05:22 AM
Agent_EM1
10
Jul 15, 2008 05:05 PM
spaceman00
17
Mar 16, 2007 11:31 AM
cnk600
Dec 3, 2002 11:53 AM
