Cant get into Reverse.. Anybody know?? HELP!!
Old May 20, 2010 | 07:46 PM
trooper0641's Avatar
Default Cant get into Reverse.. Anybody know?? HELP!!
Long story short.. bought a y8 swap from a dude (probably not the best dude) to put it into my 99 ek hatchback. Swapped it into my ek and then can't get into reverse gear but can to all the others. Seems like whenever I try to shift into reverse it always ends up being around 5th gear I believe. Anybody know whatsup? BUMP for info.
OH AND ALSO: For some reason whenever I bump the shifter to the left (1-2 gear) the bump is there but when I shift it to the right (5-R gear) the bump back action is not there for some reason. It just slacks and lays there on the (5-R gear) side.
Old May 20, 2010 | 08:00 PM
eagleslax2007's Avatar
Default Re: Cant get into Reverse.. Anybody know?? HELP!!
i have a b16 trans with the same problem, when we took it apart it was the 5-R synchro sleeve so that might be the issue, but answer i can give you, take it apart and inspect it
Old May 20, 2010 | 08:20 PM
honda_luvr_2000's Avatar
Originally Posted by trooper0641
...bump the shifter to the left (1-2 gear) the bump is there but when I shift it to the right (5-R gear) the bump back action is not there for some reason. It just slacks and lays there on the (5-R gear) side.
Sounds like you definitely have an internal transmission issue. Most likely a faulty/missing detent or return spring. But you won't know until you take off the case and inspect.
Old May 20, 2010 | 09:06 PM
D16SiHatch's Avatar
^ what he said. either way, your transmission is muffed, and that guy definitely screwed you over.
Old May 20, 2010 | 09:14 PM
93egSLEEPER's Avatar
get a new tranny man. not worth the headache. a d series tranny will be cheap and easy to come by.
Old May 20, 2010 | 09:24 PM
its a 00 d16y8 transmission!! THE BEST!! Oh and also are the parts replaceable if it were the 5-R sleeve or the return spring midjiggy or something?
the tranny seems to shift fine 1-5th gear btw
Old May 20, 2010 | 09:26 PM
is that repairable? how much did you guys spend?
Old May 20, 2010 | 09:36 PM
Yes the transmission is repairable as long as it hadn't grenade'd. Cost to repair always depends on what needs replaced. If it's a spring or detent ball- real cheap. A 5th/R synchro set- kind of costly. A gear or gear set & synchro set- not worth it. Yes you can get D-series transmissions real easily.
trooper0641
14
May 14, 2010 12:31 AM
EK SQUAD 425
Jul 5, 2006 08:30 PM
hondatuner20
May 30, 2006 07:19 AM
Rudelude22
Dec 10, 2005 08:33 AM
Radyjr
Jul 29, 2005 02:02 PM
