Pro1's with ctr pistons?
I built a poormans r with oem CTR pistons and B16 head with Pro1 cams and springs/retainers. What I'm wondering is if when In vtec will the valves hit the pistons? The head has been milled .020
Mods are:
GSR block
acl race bearings
oem ctr pistons and rings
B16 head milled .025
skunk2 pro1 cams
skunk2 pro series valve springs and retainers
mild port and polish
oem replacement headgasket
Mods are:
GSR block
acl race bearings
skunk2 pro1 cams
To be absolutely sure you should check the clearances (PTV,VTV)
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-v2v-p2v-1891614/
https://honda-tech.com/forums/showthread.php?t=1891614
So when you hit vtec you still had no problems?
old clip or a run i did with my old motor set up. close one to the screen. you can heard that vtec cross over. http://www.youtube.com/watch?v=WGeXI...layer_embedded
Chance EG
Apr 6, 2020 11:27 AM
