88 crx hf b20 swap. fuel injectors not squirting searched and stumped
How's it goin guys. I recently swapped a jdm B20b into my 88 crx Hf. I was having issues with the spark before. It was only partially convertered. The distributor clips were the only clips that were actually depinned. So I took my harness out yesterday and did the injector clips, and did the resistor box plug from the obd1 harness. I'm using obd1injectors, obd2 dizzy depinned to obd1. Now I'm getting spark so that should mean the dizzy was done correctly? Obd0 to obd1 jumper, P75 ecu. Fuel is pumping into the rail. Just injectors won't squirt. I was testing the voltage on them. And at ignition on the injectors get 12 volts and turning over they're at a steady 9.8 however the other wire at ignition on shows no reading until I turn it over it get 0.7 ohms I belive then shows nothing. I'm stumped. Any ideas guys? Also I was reading how to test the main relay. I don't hear the first click but the second and third are there. And the pump is pumping. So I figured it can't be the relay
Make sure you have the pins in the correct location on the plug. For example, the top two rows have continuity and the bottom two rows have continuity. All of the pins must be either on the top or the bottom.
MastaFlyMason
Sep 3, 2017 10:06 AM
ironman85
14
Oct 30, 2010 03:02 PM
white90rexsi
Jun 22, 2007 06:21 PM
