Converting from OBD0 B16 to OBD1, need help
Old May 20, 2010 | 08:16 AM
xotic_crx's Avatar
Default Converting from OBD0 B16 to OBD1, need help
So a friend is interested in converting his b16 swapped CRX to OBD1 since he has to replace the dizzy. I've got the p28 and chipping ability to handle that side, what we need to know is will an obd1 B16 distributor bolt up and what (if any) other harness will be needed besides the jumper harness at the ECU. Thanks a lot.
Old May 20, 2010 | 08:26 AM
tx_ej8_49's Avatar
Default Re: Converting from OBD0 B16 to OBD1, need help
Yes, the distributor will bolt up. and yes, you will need the 2 distributor jumpers, unless you want to hard wire your harness with OBD1 plugs.
Old May 20, 2010 | 08:33 AM
xotic_crx's Avatar
Cool, thats exactly what I needed to know!
white92teg
Feb 12, 2010 01:09 PM
88 EF Hatch
Aug 19, 2009 05:19 PM
ekb16
Jun 1, 2009 09:05 PM
crazyrex
Sep 16, 2005 04:14 AM
egvtec
May 25, 2005 12:23 AM
