Replace Water Temp Sensor?
Old May 20, 2010 | 06:54 AM
BlackShingo's Avatar
Default Replace Water Temp Sensor?
Ok, today I decided to test my water temperature sensor. I jumped the wires on the plug that goes into the sensor under the distributor and when I went to turn the ignition on, the gauge didn't move. The check engine light stayed on and made a weird click noise with a faint dimming, kinda like a blink. Does this mean I need to replace the temperature sensor or should I replace the water temp gauge?
Old May 20, 2010 | 07:12 AM
Jockone's Avatar
Default Re: Replace Water Temp Sensor?
The sensor for the gauge is the single wire conector not a two wire one.
Old May 20, 2010 | 07:36 AM
Yeah I figured that out lol. Well I actually tested the real one and the gauge moved, but it moved slightly downward. It didn't move up. Does that mean I have an open circuit or maybe I am not using the right kind of jumper wire?
EF_SEDAN_LOVER
Nov 20, 2014 04:06 PM
SurferDude905
Apr 17, 2009 10:07 AM
HamiltonRex
Oct 6, 2004 01:32 PM
Finest
Nov 19, 2003 08:15 AM
2000_Civic_Si
Apr 3, 2002 07:45 AM
