Suspension & Brakes Theory, alignment, spring rates....
My Breaks Are Not Working Help Please
Old May 20, 2010 | 06:09 AM
love_my_ekcoupe's Avatar
Default My Breaks Are Not Working Help Please
well i have 93 eh2 (eg) hatch, my brakes are not working. i press the pedal all the way in and still does not come to a complete stop. it rolls then stops. the brakes wont lock. i tried bleeding them. what can be the problem? it also has the BRAKE light on as if the handbrake was on. If u guys want anyother info tell me im kinda in a hurry because of class.
Old May 20, 2010 | 08:30 AM
Trey's Avatar
25 Year Member
Default Re: My Breaks Are Not Working Help Please
Is the brake fluid full? That will cause the light to come one.
Old May 20, 2010 | 10:10 AM
Ooooo, yes the brake fluid is filled up. Well yesterday I bled both of brakes and it worked perfect but then the brake light came on and this morning the brakes go all the way in. Wat can cause this? At first I coulda pump it to brake good but now wen I pump the brake pedal it doesn't stiffen up.
Old May 20, 2010 | 01:18 PM
Bump
Old May 21, 2010 | 12:25 AM
seanbev24's Avatar
"Both" as in you only bled the fronts? If so, you need to bleed all 4, in the proper order.
Also, inspect for leaks around the master cylinder, lines, and fittings all the way to the calipers/drums. If you have rear drums, pull them off and check the wheel cylinders for leaks around the rubber seals.
Or, just take it somewhere and have them checked. Just an evaluation is cheap/free at a lot of places.
Old May 21, 2010 | 06:05 AM
4 and proper order? Can u give details/ explin on that? i havent gotten a chance to look at the car due to school and other stuff but can u give me all the places to look for leaks? Where all the cylinders and all of that is? please thanks
Old May 23, 2010 | 04:33 AM
poweroftheblah's Avatar
4 because you have 4 wheels that need to be stopped
Bleeding order is right rear, left front, left rear, right front...At least thats what it is for an Integra with ABS, might not be the same for a civic...
The master cylinder is this:
Old May 28, 2010 | 03:32 AM
richi86's Avatar
im not sure if you have drums on the back or not but if you do those may need changed. if they are bad or not adjusted right your front breaks are not going to work right and you will not stop. if all your breaks are good then i would try changing the master cyl
Chilly56
Honda Civic (2006 - 2015)
Nov 23, 2019 08:46 AM
adamcm16
Apr 10, 2014 05:07 PM
Kennyjai
Oct 17, 2011 11:55 AM
bullvii
26
Oct 2, 2010 05:45 AM
donniebrasco
Oct 5, 2004 07:43 AM
