need help swapping h22 in a 91 hatch
Old May 20, 2010 | 05:55 AM
civic-one's Avatar
Default need help swapping h22 in a 91 hatch
okay all my life ive never owned a car made in the year 97 and below. Now ive got this 91 civic hatch and want to do a h22 swap. Ive tired seaching but came up with mroe questions than ever ( obviously im not no honda mechanic). Can somebody please point out any DIY swap on these cars or at least tell me whats needed other tahn motor and mounts hehe. Thanks let me know oh and also i knwo this will help the car now is running a obd2 civic harness from previous motor swap.
Old May 20, 2010 | 07:16 AM
judgeDredd's Avatar
Default Re: need help swapping h22 in a 91 hatch
depending on which mount kit you use will make the difference on what axles are required im using the hasport mount hit in my crx so im using the hasport axle pack. there are instruction that come with the mount kits(also available at the site) that tell you what needs to be done to prep the bay for the swap i have a few recommendation if you do use the hasport kit.
Old May 20, 2010 | 09:14 AM
Mike17's Avatar
Check out explicitspeedperformance.net . I am also going to be doing an h22 in a 91 hatch. Just sourcing all my parts now. I went with ESP mount kit and traction bar, TOP QUALITY! if you get their kit, it has a write up with it aswell.
Old May 20, 2010 | 02:19 PM
civic-one's Avatar
Daym good thing I asked I didnt even know I needed this much parts jsut for the swap its not like my 98 where we dropped in a b20 its was so simple. thanks for the headsup guys. Anymore tips would be greatly apprecaited like what I said i dont know anything about this civic only 97 up hehe. I know those are great brands hasport and that esp ( i wanted traction bars for the ek) still deciding though which one will be a nag for my buck here. one more is it possible in keeping the aircon
Old May 20, 2010 | 02:38 PM
mayfly's Avatar
no i believe it is not possible without extensive modification
Old May 20, 2010 | 05:31 PM
civic-one's Avatar
Okay so here. wahts the best bang or my buck here go h or go witha type r or something whcih one would you guys prefer.. i wanted H because everybody here had a B motor i want something different very few H here
Old May 20, 2010 | 05:36 PM
ef-2nr's Avatar
stick with the h22 not as diffucult as everyone puts it. Just finished mine using explicitspeedperformance mounts and trac bar just have to weld in trans mount. Be different and go with the h.
Old May 20, 2010 | 06:55 PM
ocredhead28's Avatar
h is good you might want to also think about doing the h to b trans kit that way you can do any b series trans and axles throw a itr trans and call it a day.... good luck wit it..
Old May 21, 2010 | 06:23 AM
civic-one's Avatar
anybody has some DIY links
Old May 21, 2010 | 07:10 AM
Jaime 91SiB18's Avatar
hasport has a diy I beleive
Old May 21, 2010 | 07:21 AM
h22crxpwr's Avatar
what do you want to know?
parts needed Are below.
Mount kit. Innovative is good, Hasport, etc, i use another custom brand (like innovative)
Custom Axles,
Shift cables and box.
Motor / trans
New crossmember with smaller EG radiator (innovative, etc)
Alternator relocator kit (unless you want to chop up your headlight.) innovative sells this, also evolution, and explicit speed.
Clearancing frame rail basically bashing in the lower frame rail so you can have access to change alternator belt. this is important unless you want to drop the whole motor just to change the alternator belt!
Cutting stock or getting F20 Crank Pulley (need one row pulley) i would avoid the smaller aluminum pulleys. use a stock one cut and rebalanced or an F20 pulley which comes single row. (also you need to measure the distance to the alternator and take it to your auto parts store to match up the belt. you cant use a factory h22 belt) with some kits you can also run a single cam alternator.
Cut off factory mount on trans side. bolt on the new trans mount and also weld the trans mount in.
Wiring / ECU jumper.
Cut hole for shifter box. and also hole for shift cables.
Drill holes for the mounting of the shift box. find bolts to mount box with matching nuts.
flex hose that fits the radiator.
If you want i can supply all the parts for you that you need. let me know. Good luck!!!
jdm 1080p
Oct 8, 2012 03:27 PM
highflyinhonda
Nov 14, 2005 05:32 PM
89sihatch3
Oct 5, 2004 04:53 PM
quick4thgen
Dec 15, 2002 03:59 PM
LANEVOIX
Jul 2, 2001 10:35 PM
