91 B18A1 swap into a 95 D15B7 Civic Questions
I currently bought 2 civics, one 95 and one 93 and i have decided to put a B18A1 motor and tranny i have in the 95 civic. I have the complete motor, tranny, axles, shift linkage and ecu from a 91 integra.
i know the tranny is cable and im pretty sure i can make it work.
some people say i need a newer ecu and a adaptor wiring harness and stuff but im not sure what exactly i need to do.
i was wonderings if it would just be easier to put the wiring harness from the 93 into the 95? so it wouldnt be obd1 but im not sure if that will work either.
thanks for your input!
phearable.net or xenocron.com .... there is not many tuning software out there to tune obd0 just obd1 ecus.... you already have what you need. you can send yours in and get it chipped or buy another one with a chip in it already. both places would set you up with a basemap when they send it back. just give them some info of the mods you will have on it,and they will get it in the ballpark expecially if its all stock with bolt ons.
im getting my ecu chipped but i cant seem to figure out the wiring.
what do i do with the dizzy, altonator, injectors?
and could i use my stock d15 o2 sensor in my b18?\
Once you get chipped and tuned, be careful having a engine older than your car. State Patrol gave me **** for, threatened to inpound my car, instead they gave me a huge *** ticket.
OBD0 alternators use the same plug as OBD1 IIRC, you will need to use OBD1 injectors are swap in a resistor box (you can simply reuse the D15B7 ones, they flow 240cc the same as integra injectors. You will need an OBD1 distributor.
kingmonkey
Feb 3, 2006 04:52 PM
civicracer94
May 15, 2005 01:23 AM
