b18c swap into my DB8-R need help please
Old May 19, 2010 | 09:23 PM
smiko0124's Avatar
Default b18c swap into my DB8-R need help please
Hey fellas most of you know im putting a b18c gsr swap into my db8R from a donor 1998 gsr i picked up.
Well the swap is in and the harness is on... i have a few extra plugs from the JDM itr harness that dont reach anything and a few spots on the engine that dont have anything plugged into them. I need some help.
Look at the pics and reference which pic you are answering to. Thanks in advance
Other 4 plugs to coil packs.. where does this single plug go? whats it for?
I believe this is for the thermostat but no plug from my harness reaches it or i have plugged it in somewhere else near by and nothing else reaches this area.... Also the 2 sensors on the top here do not have a plug close to them at all...
I believe these 2 hoses go from/to the same thing- my problem is the hose from jdm is smaller than the usdm hose and they will not connect to/from their locations
I can not find a location for this plug. it does not reach anything
I believe there are 2 of these plugs on the JDM harness on the very back of the motor that do not reach anything. what are they for?
P.S. I know I suck, thanks for the help in advance
Old May 20, 2010 | 08:06 AM
cheezthis's Avatar
Default Re: b18c swap into my DB8-R need help please
I'm having trouble identifying what I'm looking at in the pics. One of them looked like a VSS though? The thermostat is in a different spot on a gsr head vs b16/itr head, so keep that in mind if it's close but does not reach.
There's also o2 sensor and so on.
You need to go through what is connected already, and start narrowing down from there.
dteng
Feb 28, 2008 03:23 PM
CloudDragon
Feb 2, 2005 11:38 PM
Nameless RB26
Oct 13, 2002 10:56 PM
Second2None
May 24, 2002 06:12 PM
