NA Built GSR/ITR motor (OHIO)
Old May 19, 2010 | 09:09 PM
shockerjoe says's Avatar
Default NA Built GSR/ITR motor (OHIO)
contact info:
roosedustin@sbcglobal.net
call/text (330) 428 1823.
price: $4200.00 or.best.offer. (willing to work a little on the price)
Complete swap, into any 92-95 civic or 94-01 integra or 96-00 ek chassis civic.
Engine:
0 miles on this build, Built by Slowmotion Motorsports in Columbus Ohio.
B18c1 GSR Block, decked .010.
Bored to 81.5mm.
Micro Polished crank.
Balanced Bottom end rotating assembly.
Manley Connecting Rods.
CP 11.5comp pistons.
Ferrera Stainless valves.
HOP Honda ITR valve springs, retainers.
HOP ITR Timing Belt, water pump,oil pump, oil pick up and oil pan.
ACL Race bearings.
P72 GSR Head, Decked .010 and a Mild port and polish to both intake and exhaust side ports.
Hondata Intake manifold Gasket.
Skunk2 Intake manifold.
HOP ITR Valve cover. (red)
ARP Headstuds.
Cometic Head gasket.
Stock GSR Cams and Cam gears.
HOP Dizzy with New, cap & rotor.
NGK Iridium plugs +1 stg hotter.
NGK 8.8mm Wires.
Transmission:
Stock GSR transmission, gone through by Slomotion and I had all NEW Sincros put in every gear, simply because i wanted everything to be tight,fresh and legit.
Exedy Stage 2 Clutch and Pressure Plate.
Original Flywheel, Re-Surfaced.
Gsr shift linkage w/ Buddy Club weighted shifter.
OEM Axles and intermediate shaft.
Wiring:
I will include with this price the full engine harness and ecu, it is uncut and i have it wrapped up nicely here in my house so no moisture could get to it.
Paper Work:
I have here all of the receipts and records of this Build. I will do MY best to include every piece that is to this engine and the parts along with it.
Additional info:
The engine was built in the summer of last year. I have never drove it or started it for that matter, family occurrences came about and since that time i hadn't really the time id like to get it on the road. I have listed it other places and honestly i would like it to go as a Whole piece. I AM WILLING to work on the price a little bit and or arrange for shipping. I am willing to drive/meet half way for a SERIOUS Buyer.
Please feel free to contact me how ever you choose. I will respond as quickly as i can.
Old May 20, 2010 | 06:01 AM
Default Re: NA Built GSR/ITR motor (OHIO)
bump
Old May 20, 2010 | 09:28 AM
slick1851's Avatar
This thing is not itr motor and it does not have a sort ratio itr tran, why are you saying it's itr?
Old May 20, 2010 | 11:38 AM
Bump
Old May 20, 2010 | 08:41 PM
bump
Old May 21, 2010 | 07:04 PM
B.J.'s Avatar
so close, sorry u didnt get it done. Hope u get what its worth
Old May 21, 2010 | 07:11 PM
boosting4life35's Avatar
bump
Old May 22, 2010 | 01:51 PM
thnx
Old May 24, 2010 | 11:04 AM
BUMP
Old May 24, 2010 | 08:21 PM
bump
Old May 25, 2010 | 06:42 AM
morning bump
Old May 27, 2010 | 10:10 PM
BAMP
nabin
Texas -OK -LA (Sales)
Jun 21, 2007 09:25 PM
crx_0_o
Sep 8, 2006 09:05 PM
Cheeks153
Sep 5, 2002 12:44 PM
eddiecut
20
Jun 8, 2002 02:39 PM
DuMbAssInCaRz
Jan 6, 2002 06:53 AM
