looking for info on how to do timing on B18c1
I just picked up a 1998 GSR, 3days ago, the previous owner took it to a shop which diagnosed that it has bent valves in cyl#1 compresion test as follows...
cyl#1 27psi
cyl#2 205psi
cyl#3 210psi
cyl#4 210psi
I almost have the head taken off, just need to pull a few sensors off and the radiator hoses from the head.
Im planning on taking the head to the local machine shop, assumeing that the guide(s) are trash along with one or more valves.
can anyone tell or direct me to a step by step process for reinstalling the timing belt and how and where to line up the pullies for correct timing.
THANKS FOR ANY AND ALL HELP!
cyl#1 27psi
cyl#2 205psi
cyl#3 210psi
cyl#4 210psi
scanning through titles theres nothing.
but i found what i needed via
***How-To*** Install Valve Springs & Valve Stem Seals
