JDM GSR swap into my civic questions
Old May 19, 2010 | 12:19 PM
vsmftw98's Avatar
Default JDM GSR swap into my civic questions
Okay, I swapped a OBD2 JDM GSR into my 1998 ex coupe. I reused my ex wiring harness, obviously.
I have some problems.
2 CEL's, one for knock sensor, and the other is primary heater o2 sensor.
I bolted up the JDM gsr header to my stock civic exhaust, it barely fits and rattles because the flanges don't line up.
What cat. do i need? I know i have two o2 sensors for my obd2 civic but im just not sure what will be a direct fit..
That is my main concern, I also broke my fan switch next to my thermostat during install, I've NEVER heard my fan come on ever since the swap (1 month) I do have overheating issues and they only happen on the highway at speeds of 65+
Any help would be much appreciated seeing how im doing this all on my own and its myfirst swap...
Old May 19, 2010 | 01:48 PM
ekb16's Avatar
Default Re: JDM GSR swap into my civic questions
i would just go to a muffler shop and have them redo the exhaust with the stock muffler on it. if you want to run a cat, get yourself a universal magnaflow cat and have them weld some flanges on it. if you don't want a cat get yourself a test pipe
Old May 20, 2010 | 11:43 AM
vsmftw98's Avatar
I went to one and they said they wouldnt want to cut and weld it.. I have heard that I can get a 99-00 GSR cat. I have a JDM header so i think its a bit longer and has a o2 bung on it already..
Im just pretty confused at this point
Old May 20, 2010 | 08:48 PM
DARKSIDE:EG6's Avatar
I COULD USE SOME HELP WITH A GSR SWAP.I'M NEW SO I DON'T NO WHERE TO GO
Old May 21, 2010 | 11:14 PM
chewyv's Avatar
pm4nudes
than go to another one. unless you live in a state where they prohibit this stuff.
Old May 21, 2010 | 11:17 PM
chewyv's Avatar
pm4nudes
find a local hondatech memeber. and pay him. then your all set.
Old May 26, 2010 | 06:47 PM
I CAN SWAP A MOTOR JUST FINE.I'VE DONE 3 IN MY HATCH.I JUST NEED SOME WIRING TIPS FOR OBD2 TO OBD1
Old May 28, 2010 | 07:13 AM
vsmftw98's Avatar
I'd appreciate it if you made your own thread, im trying to find answers here...
Im not so worried about the exhaust for now, i have one bigger problem:
When climbing RPM's i get into my 1st stage of vtec and it is hesitant, it is almost skipping like its misfiring. I just replaced my sparkplugs..
Still doing it, is it because im running to rich from not having o2 sensor?
Ephekt
Jan 2, 2013 04:53 PM
lcsej1
Jan 16, 2009 11:01 AM
aZnjCC
Jul 17, 2004 09:19 PM
Tomatohatch
Jun 13, 2004 12:19 PM
daxxbomb
Dec 30, 2002 04:08 PM
