Removing rear hatch - 96-00
Hey guys I did a quick search and couldn't come up with anything. I am just on coffee break at work and don't have much time to give the internet a solid look through. I am pulling a rear hatch of a 99 civic hatch after work and I need to know how and where to disconnect the loom of wires from the roof to the hatch (rear defrost, wiper, etc.) Thanks!
The wiper is held on by 1 nut, but the assembly is held on by 3 nuts on the inside of the hatch under the interior panels. Also when you pop the hatch, there should be a clip on the top right side that goes into the chassis, not positive if its for the 3rd brake light tho. Other than that, you (Should) be able to pull that Ish off.
DETALZ
Jun 21, 2007 07:06 PM
