brakes won't lock
Old May 19, 2010 | 08:42 AM
wickedplastikman's Avatar
Icon6 brakes won't lock
i noticed that the brakes won't lock on my 93 del sol si. even practically standing on them. i bought a new master cylinder. bought a 15/16s new for a 91 civic sedan. bolted right up.
i bench bled it according to the directions with no problems. installed it, flushed the lines, and replaced the brake fluid with dot 4. bled the wheels several times, and each time it's the same problem. the car slows down but none of the wheels will lock if i slam on the brakes.
there is no abs on this car.
i pulled all the calipers off and checked the pistons. pushed them out and re compressed them. all of them seem fine. 1 was new from the last brake install about a year ago. rotors are wearing normally.
as far as i know, its the master, booster, lines, and calipers. nothing else makes the brakes work.
turned the car off and pumped the pedal. its building pressure and the pedal gets stiff so i didnt think its the booster.....
any suggestions? anybody else have this problem?
Old May 19, 2010 | 09:39 AM
forcefedeg01's Avatar
Default Re: brakes won't lock
hmm, i have the same issue, new calipers, pads, master cyl off a gsr with prop valve and new everything out back too...
kfw5045
Aug 20, 2014 10:29 AM
wickedplastikman
Suspension & Brakes
May 24, 2010 10:09 PM
JDMPR
Jul 18, 2009 02:09 PM
gophat
Jan 6, 2007 05:11 PM
TnVol
Sep 18, 2002 05:45 AM
