help!!!
Old May 19, 2010 | 07:43 AM
dxlol's Avatar
Default help!!!
so i have a 95 coupe that i bought from a friend not running for $500. It had low compression in a cylinder so i said f that motor. I had a d15b8 in my backyard. I put it in and i cant get rid of this check engine light.... the stock motor in a 95 dx is the d15b7. my friend has a 94 hatch thats where i got my d15b8 motor from. but he popped a d15b7 in and has no problems... why is this? and why when i hook up a scanner to my car it cant read anything?? please help.
Old May 19, 2010 | 08:23 AM
mooze's Avatar
Default Re: help!!!
what r the cels?
Old May 19, 2010 | 08:41 AM
dxlol's Avatar
Default Re: help!!!
when i hook up my scanner to it, it wont read. it says no connectivity. so i cant check the code, but when i hit clear codes it clears it for a second and then it comes back...
Old May 19, 2010 | 03:04 PM
mooze's Avatar
Default Re: help!!!
ok so use the jumper method....
http://check-engine-light-codes.blog...retrieval.html
Old May 19, 2010 | 04:10 PM
shawn_crx's Avatar
Default Re: help!!!
Depend what year ECU you are running and what year is your D15Y8.
I swap out my D15Y8 for D15Y7, I had to convert my O2 wires, and ECU for that year model.
Old May 21, 2010 | 09:46 AM
dxlol's Avatar
Default Re: help!!!
code 10 and 41 came up. intake air temp. sensor and heated o2 sensor. i have an extra heated o2 sensor but where is the intake air temp. sensor?
Old May 21, 2010 | 09:50 AM
jdmh22eg2's Avatar
Default Re: help!!!
IAT is in back of intake mani should be a white or brown sensor screwed into back of mani near dr side of motor
Old May 21, 2010 | 09:53 AM
dxlol's Avatar
Default Re: help!!!
so i have to replace the sensor on the harness huh
Old May 21, 2010 | 09:56 AM
jdmh22eg2's Avatar
Default Re: help!!!
no it is not on the harness it is in the back of mani as i said intake mani and it may not be bad i had same code for my o2 and my IAT sensor was bad and threw O2 code
Old May 21, 2010 | 10:03 AM
dxlol's Avatar
Default Re: help!!!
so how can i go about clearing this code? i need to clear it so i can get my car smogged
Old May 21, 2010 | 10:06 AM
jdmh22eg2's Avatar
Default Re: help!!!
well the IAT sensor may be causeing the O2 code and the IAT sensor is cheaper than the O2 try replacing the IAT first then pull (+) term of battery and pull ecu fuse from under hood fuse box for 30 sec-1 min then check codes again see if they go away
Old May 21, 2010 | 10:44 AM
dxlol's Avatar
Default Re: help!!!
ok. ill try that and get back to you
Old May 21, 2010 | 10:45 AM
jdmh22eg2's Avatar
Default Re: help!!!
u can pm me if u need more help
Old May 21, 2010 | 11:00 AM
dxlol's Avatar
Default Re: help!!!
thanks ill keep you updated
toneloq33
Jul 26, 2007 12:49 PM
Glen Tennis
Nov 24, 2005 10:37 AM
Charlie Moua
Jan 13, 2003 08:32 AM
