Eg swap B18B Map sensor connection.
Old May 18, 2010 | 08:22 PM
civicegb18's Avatar
Default Eg swap B18B Map sensor connection.
Hi there I am quite new here and new to honda also. So I bought a empty shell of a civic dx 92 auto, and swapped a 1996 B18B1 5 spd MT.
So far everything when good, now I need to know how I do wire and install my vacum to this thing, I don't have the charcol canister, i dont know if it could make so difference. 1 do have 1 map sensor on the firewall of the car and also one on the intake manifold near the throttle body, so first of all , witch is the good one to use and what vacum need to be plug there, If you have any pics that would be wonderfull.
Thank you very much, and sorry for the bad english, i live in canada.
Old May 18, 2010 | 08:46 PM
Matt93eg's Avatar
Default Re: Eg swap B18B Map sensor connection.
You will need to use the MAP Sensor that is on the LS throttle body and ditch the firewall mounted one.
93redcb7
12
Jun 15, 2016 02:22 AM
idriveahonda
Sep 22, 2011 02:06 PM
mangabay
Jan 25, 2008 08:50 PM
bimmeracer
Nov 6, 2007 11:41 AM
DXK Eg
Feb 11, 2005 05:05 AM
