del sol shift linkage question
Old May 18, 2010 | 06:30 PM
efjones9's Avatar
Default del sol shift linkage question
Simple question.Would a ef d series shift linkage fit a del sol?
Eran's Avatar
HT White Ops
Default Re: del sol shift linkage question
Nope.
Old May 18, 2010 | 06:35 PM
efjones9's Avatar
Would I need to get a del sol's original linkage?
Old May 18, 2010 | 08:12 PM
Eran's Avatar
HT White Ops
No. Get one from a 96 ford taurus.
Yes, you need the del Sol linkage.
Old May 18, 2010 | 09:28 PM
-Gambit-'s Avatar
wow i actually lol there, thanks eran
Old May 18, 2010 | 10:00 PM
fryman's Avatar
If length is the only problem then you can measure and cut a section out of the linkage and weld it so it will be shorter....that is if you're having trouble finding the del sol shift linkage.
Just saying......
Old May 18, 2010 | 10:14 PM
Eran's Avatar
HT White Ops
The del Sol ones are actually longer. Read first, answer questions later.
Old May 18, 2010 | 10:34 PM
fryman's Avatar
I wasn't sure if it was the length or what...that's why I said IF.
Read first,reply later.
Old May 18, 2010 | 10:37 PM
Eran's Avatar
HT White Ops
Your speculation on a technical issue is of no concern or of any consequence.
Remove head from sphincter, then post.
Old May 18, 2010 | 10:55 PM
fryman's Avatar
Hey,I'm just trying to help the man out by providing a alternative option he may not have thought of.
If the shift linkage is too short then all he has to do is cut it and add a pipe of the same diameter as the shift linkage and of course measure it so that it will add the right amount of length.
Of course it will be much much easier to just get the right part but maybe he can't get one and that's why he wants to use one from an ef.
At least I'm trying to help instead of being sarcastic.
"No. Get one from a 96 ford taurus.Yes, you need the del Sol linkage." you say that as if there was an obvious answer to his question even though many Honda parts are interchangeable so it is a completely legitimate question.
You are just like 3/4 of the people on this site that think everything is a joke and having a good laugh is your main concern,not trying to help people like it should be.
Old May 18, 2010 | 11:03 PM
Mr. Winky's Avatar
you sure its not a 97..............mercury sable ;/
Old May 18, 2010 | 11:09 PM
efjones9's Avatar
cuz there are some people trying to find answers. Sarcasim is funny but some people push it too far.
Old May 18, 2010 | 11:20 PM
Eran's Avatar
HT White Ops
There was an obvious answer, and it's been gone over:
You have to use del Sol linkages for del Sol's. Period. I thought we covered this, but apparently people want to ghetto-rig their cars and use the incorrect parts.
Just use the right part and nobody gets hurt.
Old May 18, 2010 | 11:24 PM
Eran's Avatar
HT White Ops
I'd also like to point out that I'm not like 3/4 of the people here, just trying to get a laugh.
I am trying to help. I'm the ONLY person in here who provided the correct information.
Old May 19, 2010 | 05:33 AM
jayjona8732's Avatar
here you go if you wanna buy one that will fit your sol
http://www.hamotorsports.com/delsollinkage.html
da_driver_15
Dec 28, 2010 05:42 PM
skUnK2jdm
Sep 19, 2007 11:52 AM
SOLvtec
Oct 27, 2006 09:30 AM
jd_bh03
Jul 14, 2004 02:15 PM
aeolus
May 27, 2003 10:00 PM
