Cold or Hot Spark Plugs
I know that cold spark plugs are to prevent the plug from igniting the mixture too soon. And at Higher RPM you would need a colder spark plug because the plug is going to be running more often and therefore hotter.
My question is, Are the any repercussions to using a cold spark plug when it's not necessarily needed?
I have never heard of this cold spark plug...hot spark plug??
colder plugs are for forced induciton use.
, but that's not exactly what I was asking.[Modified by DarkKnight[DMD], 10:16 AM 9/12/2002]
you are talking about different heat ranges as per spec'ed on the plugs
for example Denso IK16 or IK20 is equal to a heat range of 5 or 6 respectively...
The reason for this is that the proper range allows for the plug to heat up to a temp that will keep the electrode and ground clean without detonation...With Cams and compression, boost or NOS, you go one to two steps colder as it is an increase of cylinder pressure...
i think stock GSR is IK16 or #5
add boost or anything go up one to two ranges
I have to find the post on this as it has more details
i didnt replace my stock plugs when i got the blower install d ..as a result the plugs foul d withing minutes..i would think something would happen to a colder plug if it wasnt necessary
RACEPAK
Sep 21, 2005 04:08 AM
