check engine light code check
Old May 18, 2010 | 10:55 AM
bradennicely's Avatar
Default check engine light code check
is this were your supose to check codes?
i have a 90 crx with a b18b converted to odb1
this is underneith the pass. side dash
Old May 18, 2010 | 11:15 AM
D16SiHatch's Avatar
Default Re: check engine light code check
yep is certainly is. jump that connector and the cel in the gauge cluster will start blinking out codes
Old May 18, 2010 | 11:21 AM
and just put an wire touching
Old May 18, 2010 | 11:22 AM
sorry
just touch the 2 wires in the clip together?
Old May 18, 2010 | 01:27 PM
Old May 18, 2010 | 01:48 PM
ef yu's Avatar
yes. bridge that two wire connector together. you can use a paper clip or just grab a wire and strip the ends off.
Old Jul 18, 2010 | 10:47 AM
jhetz's Avatar
I'm having the same issue with my crx. But my CEL only comes on after driving for a couple minutes. If I jump the connector before the CEL comes on will it still spit out a code? Or do I have to drive it til the CEL comes on before I jump the connector?
thanks for the help
4DALOOKS92
Apr 16, 2016 07:46 AM
76 camaro car
Aug 1, 2015 12:11 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
kevinoneill
Feb 3, 2005 12:05 PM
