1995 Accord problem(I need help)
Hey guys, I have a 1995 Honda Accord, My radiator busted I had changed it. I then put in a used radiator and my tranny fluid came out to be a milky substance(light brown in color.) I then flushed it all out bought a new after market radiator installed it. Then I went to drive it and the transmission will not shift properly. So I drove it up and down the street seeing if I could burn it off, well last night the tranny will not grab any gear. It will not even go in reverse. Can someone help me diagnose this problem? I am thinking it is the filter. I know it's not my head gasket because I checked my oil and where the gasket is and everything seems fine. Thanks in advanced.
Yeah, I flushed both the coolant system and the transmission. Both were their original colors. But when I started the car it shot the dirty substance back through. I am assuming it's deep in the system somewhere. Thanks for the help dude. I will go back out and check it I may have video and/or photos up some.
The thing is I do not know where it is coming from. All I can say is it looks like a brown milky substance. I have no idea where it keeps coming from because I know I flushed everything out multiple times. And yet whenever I pull out my dipstick to my tranny the substance is still there. I will have photos of it up in about ten minutes. Sorry man I don't know all of the technical terms. So it's kind of hard for me to really point it out but like I said I will have pics posted in about 20 mins. Thanks for the help.
http://i584.photobucket.com/albums/s.../Image0214.jpg
http://i584.photobucket.com/albums/s.../Image0213.jpg
Now my car won't turn over. I think it maybe the battery I will check it soon. But I have oil where my spark plugs are. Is this a problem?
you're replacement radiator probably has a deffective cooler for your trans.fluid. Is your coolant also milky? If it is, get another radiator and you would probably have to flush your tranny fluid a few times to get rid of that coolant/tranny.fluid mixture.
wildcard369
Nov 1, 2016 10:13 AM
MJ 95 del sol
Jan 3, 2013 07:41 PM
mfrund
Aug 9, 2005 08:45 PM
First Honda 1976
Dec 6, 2004 02:39 PM
