Flush Fluids or Replace Transmission Accord 08
Within the last 2 weeks or so my radiator broke and started to leak coolant into my transmission missing the two fluids. If I replace my radiator and flush the fluids out what are the chances transmission will be fine and continue to work properly or should I look at replacing the radiator and transmission instead since moisture has gotten into the transmission?
Re: Flush Fluids or Replace Transmission Accord 08
Hard to call.....at the very least I would be doing several "drain and fills" of the trans fluid once the new rad is in.
It is one of those where how much/how long was this going on - did it just take a few thousand miles off the trans or is it shot.......was the trans acting up before you parked it?
jasander77
04-26-2023 04:19 PM
whiskywaterwine
06-09-2017 12:36 PM
GKIN
08-21-2004 05:32 AM
