whats this on the IM?
Old May 18, 2010 | 08:14 AM
jakl's Avatar
Default whats this on the IM?
its in red, mine doesnt have it. not sure what year the diagram is but mines a 94 gsr.
Old May 18, 2010 | 08:15 AM
jakl's Avatar
Default Re: whats this on the IM?
is that the evap solenoid that jdm gsr's dont have??
Old May 18, 2010 | 08:19 AM
Sr420Det's Avatar
its a purge valve u dont really need it, for emission purposes (fumes from the gas tank). Yeah the jdm's dont use it
Old May 18, 2010 | 08:59 AM
Adamvanxxx's Avatar
Sorry for the off topic, but where did you get this picture I have been needing one like this for a y8.
Old May 18, 2010 | 09:14 AM
Sr420Det's Avatar
search oem honda parts...really anywhere that sells factory honda parts should have these diagrams
Old May 18, 2010 | 09:37 AM
Adamvanxxx's Avatar
Yea I have been doing that I need the hoses.
Old May 18, 2010 | 09:45 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Yes, evap purge.
Although you do need it if you're running a USDM ECU. It will throw a CEL without it, but will not cause limp mode.
I've got mine intact on my GSR, but I'm running OBD2b USDM engine and ECU.
Old May 18, 2010 | 10:11 AM
Sr420Det's Avatar
Originally Posted by Vindicator9000
Yes, evap purge.
Not always, iv ran mine without it plugged in on my z6 factory p28 with no cel
Old May 18, 2010 | 10:24 AM
Actually, you're right. Sometimes I forget that I'm one of the few on honda-tech who runs OBD2 on a swap.
It will throw a code on a USDM OBD2 ECU. It shouldn't throw a code on an OBD1 ECU or a JDM OBD2 ECU.
Old May 18, 2010 | 10:56 AM
Sr420Det's Avatar
Did not know that.
To the person asking to get this pic, there is a list of oem parts dealers stickied to the top of the 92-00 civic delly forum
Old May 18, 2010 | 11:36 AM
jakl's Avatar
the pic is from some acura parts dealer. not sure where i found it. and how do i run the vacuum line for a gsr without the evap? just from the vacuum tank to the intake manifold? also, there is a vacuum hose on the throttle body and im not sure where that goes. anyone have any idea? right now its on the vacuum tank as well but i wanna make sure its right
Old May 18, 2010 | 02:10 PM
Sr420Det's Avatar
Yeah just run it to the throttle body (should b before the throttle plate on the filter side) from the charcoal canister. One of them goes to atomosphere, one to purge, and one to throttle body. i think
swiftstyles
Oct 24, 2009 02:24 PM
shoklid
Apr 17, 2009 09:30 PM
elnoyl
May 15, 2006 07:43 PM
nomotor
May 4, 2004 01:57 PM
Judah
Sep 23, 2003 05:34 PM
