Zc DOHC PG7 or PM7 or PM6.....?????? HELP!!
Old May 17, 2010 | 04:19 PM
jabiboo's Avatar
Icon2 Zc DOHC PG7 or PM7 or PM6.....?????? HELP!!
ok so I have a 90 Dx hatchback which I'm putting a Zc DOHC in to but I don't know which ECU use. I'm looking for the best ECU choice with out having to reprogram it.....
I have red that the PG7 works good, but I have also red that the PM7 works fine as well. Pleasse HELP me!!!!!!!
Old May 17, 2010 | 08:50 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Zc DOHC PG7 or PM7 or PM6.....?????? HELP!!
PM7 is the correct ECU for the DOHC ZC
PG7 is the next closest thing to it (it's meant for the 1.6 DOHC Integra)
PM6 is the fallback ECU, works just fine.
Old May 17, 2010 | 08:52 PM
BiG ChOr!Zo's Avatar
pm7
Old May 18, 2010 | 02:30 AM
SlobberGoat's Avatar
Does your DOHC ZC have a CPS on the end of the exhaust cam?
Then go for a PM7 ECU.
Old May 18, 2010 | 02:47 AM
elvis3000's Avatar
my car is EF3 zc dohc twincam JDM. ori ecu pm7
Old May 18, 2010 | 02:10 PM
jabiboo's Avatar
Yes it does have a CPS
Old May 18, 2010 | 02:21 PM
jabiboo's Avatar
Can I find a PM7 here in the US if so in which car?
Old May 18, 2010 | 03:08 PM
killerX's Avatar
TODA Spec E.C.U. PM7 oh my god its like a rocket ship.fly me to the moon in my CR-X
Old May 18, 2010 | 03:30 PM
dacrxguy's Avatar
hmotor might have them but he list them at 150 dollars
Old May 18, 2010 | 05:43 PM
24TEN's Avatar
PHANTOM MENACE
The US never had a car that came with the DOHC ZC engine so you won't find it stock in any car stateside.
Old May 19, 2010 | 01:20 PM
jlicrx's Avatar
get the USDM 88-89 (not 86-87) Integra PG7 - it will work just as good as the JDM PM7 and doesn't have the speed limiter like the PM7 - both PM7 and PG7 have fuel cut-off at 7500 rpm - the PM6 ECU for the 88-91 CRX/Civic Si/EX with D16A6 engine will work but has fuel cut-off at 7000 rpm
Old May 19, 2010 | 02:13 PM
ChokolAwt's Avatar
why not buy a chipped ecu with a pm7 mapped burned on it?
if you do use a pg7 you'll notice a slight loss of power between 3k-5k where its excessively rich at wot.
Old Jul 18, 2010 | 10:01 PM
jabiboo's Avatar
Icon2 Car won't start.... HELP!!
Having trouble with my ZC. I got a PG7 ECU. I have check the rewiring and they seem fine. The light on the ECU flashs 10 times which on the Honda manual means theres a problem with the intake. What i would like to know is if it means the same on the ZC engine or if its different? Also if any one can give me any other ideas on what to check or what can be wrong?
Old Jul 19, 2010 | 11:26 AM
1QuikSOHCZC's Avatar
Icon6 Re: Zc DOHC PG7 or PM7 or PM6.....?????? HELP!!
On a dohc? On a sohc yea. But it will run fine on a dual cam zc. For 150 u can get a chipped ecu with a pm7 map From xenocron. So u can have options if u decide to upgrade later instead of buying the stock pm7.
Old Jul 19, 2010 | 11:33 AM
Deetz's Avatar
Crazy Honda Guy
Things in this thread make me laugh. I ran a dohc zc back in the day, and ran the usdm PG7 with no issues!!!! It didn't run funny, rich or lean. You can get one at the junk yard for $15-$20, plug it in and call it a day.
I made sure my car ran well, i had a new dizzy with cap and rotor, and a fresh o2 sensor. I actually got better fuel mileage with the zc over my stock Si engine
Old Jul 19, 2010 | 03:08 PM
jabiboo's Avatar
Post Car won't start.... HELP!!!!
Sorry everyone I'm kinda new to this site and I'm still learning on how to post things. Anyways I'm having trouble with my ZC. I got a PG7 ECU. I have check the rewiring and they seem fine as well as the timing belt. The light on the ECU flashes 10 times which in the Honda manual means there's a problem with the Intake air temperature. What i would like to know is if it means the same on the ZC engine and if it is what to check or how to fix this or if its different what to do? Also if any one can give me any other ideas on what to check or what can be wrong? Thanks for any HELP!!!!
Old Jul 19, 2010 | 10:29 PM
kamui427's Avatar
http://www.d-series.org/forums/dohc-...arts-list.html
this link should tell you what u need. for parts an such, and code ten is the air intake sensor, check if its unplugged.
picture is that air intake sensor on the drivers side of the intake manifold. if i remember correctly.
prelude182
Jan 4, 2009 04:12 PM
BlueRex1020
Oct 11, 2006 05:03 PM
ek_99_SiR
Feb 21, 2004 02:23 PM
stock_cx
Dec 31, 2003 10:26 AM
crx(gator)
Mar 23, 2003 06:11 PM
