have you used this hidden fm antenna?
Old May 17, 2010 | 03:39 PM
follie gatts's Avatar
Default have you used this hidden fm antenna?
i am considering this antenna:
http://www.kapscomoto.com/Hidden-AM-...ssic-p572.html
http://www.amazon.com/gp/product/ima...1&s=automotive
i don't know if it's made by kapsco, i can't find an indication of any brand name. i am interested in it because of the built in amplifier. i won't mind this black box at the top of my front or rear window.
a lot of these style antennas have bad reviews on amazon, but most don't mention 12v wire for the amplifier. this one only has 2 reviews but both are decent.
has anyone used this specific antenna?
Old May 18, 2010 | 09:44 AM
VegaS10's Avatar
Default Re: have you used this hidden fm antenna?
That looks similar to a Metra one I've used in the past. It picks up local stations...ok, but it can't match the reception of the OEM one.
I also have it placed high in the windsheild with no tint in the way.
Old May 18, 2010 | 11:25 AM
i wouldn't expect any antenna smaller than the OE whip style to perform better. i ordered it. i found a few similar to this including the dakota digital. most of their instructions and reviews mention a 2 inch distance between the unit and any metal. i will post again after its installed. thanks for the reply.
Old Jul 1, 2010 | 08:17 PM
crap so far. velcro strip stuck to glass until an 85 degree day. reception is disappointing. i am going to try shortening the wire. there is some excess looped up and taped that i am going to cut out.
Old Jul 2, 2010 | 12:21 PM
nsxxtreme's Avatar
What I have always done and has worked really well is just buy a "wire" antenna. An antenna is made up of two parts and outer shield and then the center conductor which is the "antenna". Buy a wire antenna it usually has the shield for about 6 inches then the center conductor sticks out. Route this through the car away from any sheet metal for best results. These usually cost <$5. I have found "amplified" antenna's to always be disappointing.
ttyl4cereal
Apr 17, 2013 01:55 PM
Charlie Moua
Audio / Security / Video
Nov 15, 2011 05:30 AM
silentdeath12886
Sep 21, 2006 11:33 AM
93dx
Jul 22, 2005 06:57 PM
Ef Whore
Dec 24, 2002 01:36 PM
