antenna problem
Old Apr 16, 2013 | 09:55 PM
ttyl4cereal's Avatar
Default antenna problem
i snapped my oem antenna off my '01 integra gsr and now i'm trying to add a mini antenna in it.
what do i need for this to work? someone told me a new antenna base?
if you're experienced or know what i need to do in order for me to get my new mini antenna installed, pls let me know
Old Apr 16, 2013 | 10:19 PM
m4xwellmurd3r's Avatar
Default Re: antenna problem
Is there a stub left over from where it broke? those little universal antenna usually have a sort of collar attachment that go over the busted antenna, and are secured with a set screw.
Old Apr 17, 2013 | 11:20 AM
there was a little black thing around the area, but i threw everything away. i'm only left with a mini antenna
looks like this
http://passwordjdm.com/images/products/8403L.jpg
Old Apr 17, 2013 | 11:29 AM
Lemme guess, you threw away the black metal thing that was screwed into the bottom of the antenna didn't you?
You screwed up
Old Apr 17, 2013 | 11:30 AM
3rdtimecharmer's Avatar
10 Year Member
You screwed up
lmfao
Old Apr 17, 2013 | 11:58 AM
fcm's Avatar
fcm
Old Fart
Yea, lot's of help here.
ttyl4cereal, just go and buy a cheap universal replacement ant., [non powered] and if you want that stubby look, cut the mast off the replacement ant. and stick on the stubby one. 94
Old Apr 17, 2013 | 12:27 PM
Walmart sells stubby masts like that one for I think 8 dollars lmao. I had one on my car, but since I don't even have anything left of the antenna I kinda just shoved it into the hole and forced it to fit. Guess I should've put something in it to make it hold more secure but I didn't really care at the time. I don't really ever use the radio.
Old Apr 17, 2013 | 12:33 PM
thank you. you've been very helpful unlike these others.
i'll try this out and let you know
Old Apr 17, 2013 | 12:39 PM
http://www.walmart.com/ip/Scosche-RM...tenna/16652627
That's the one I got. It's dirt cheap and does the job. It has the pieces needed to mount it to the stub left over of your old antenna.
Old Apr 17, 2013 | 01:32 PM
thank you! very helpful man
Old Apr 17, 2013 | 01:55 PM
fcm's Avatar
fcm
Old Fart
What m4xwellmurd3r linked is perfect for what you need, no cutting, just use the adapter you need to fit your stubby to that universal base. 94
lancerkid06
Feb 27, 2010 08:56 PM
fergs96integra
Jan 11, 2006 03:06 PM
wizurd
Jan 29, 2002 03:09 PM
