Rear disc barke confusion 90 crx
Old May 17, 2010 | 02:15 PM
bradennicely's Avatar
Icon6 Rear disc barke confusion 90 crx
ok i found a how-to on crx community and they said you can use the rear disc off of 90-2000 integra. i thought it was only off of 90-93 but anyways this is what it said
1. Buy your disc set up (any 90-2001 Integra, 90-91 CRX Si, 92-2000 Civic or 93-97 Del Sol with rear discs will work)
2. Since you'll have the rear end completely disassembled, check for any tear or anything that needs to be replaced (i.e: bushings, brake lines, stock shocks, etc.) and check your master cylinder and booster in case they need to be replaced.
3. BE SAFE!!! . I know everybody here would rather hear from you asking how to fix something in your car than hear that you got hurt fixing your car. BE SAFE.
( *You will need to use your REX compensator arm because it is longer. The one from the swap might be smaller and will not let the trailing arm sit properly in its place. )
is this correct? b/c if it is it would be nice since i have a 96 gsr donor car in the drive way
Old May 17, 2010 | 03:15 PM
Default Re: Rear disc barke confusion 90 crx
anyone?
Old May 17, 2010 | 03:35 PM
I heart My EF Sedan's Avatar
i'm pretty confident that the rear trailing arms are all the same.. should bolt right up, including the e-brake cables
the fronts knuckles are the ones that are different 90-93 and 94-00..
someone can correct me if i'm wrong
Old May 17, 2010 | 03:40 PM
ef yu's Avatar
i had 92-95 civic si rear disc brakes and they had fit no problem.
EXCEPT the e brake cables did not fit.
i had 90-93 integras cables and they fit, BUT were too long on my crx.
i had a 91 civic SIR and they fit, but still the cable were a bit longer.
the only thing you need to get are CRX SI e brake cables. get those and put them on with your rear disc brake set up.
Old May 17, 2010 | 05:43 PM
DustinRose's Avatar
i have 97 integra ls arms on mine and they fit just fine
Old May 17, 2010 | 06:30 PM
with the 97 arms did you run the ebrake cable from that as well?
Old May 18, 2010 | 06:21 AM
Jockone's Avatar
Your best bet for e-brake cables is to use the 90/91 CRX si with rear discs,they are made for the car and will fit properly.
Old May 18, 2010 | 11:23 AM
alright now that the rear is settled and i have a gsr just sitting in my drive way can i use the front knuckles with a skunk2 camber kit? anyone ever done this?
Old May 18, 2010 | 12:32 PM
anyone?
Old May 18, 2010 | 03:42 PM
Jockone's Avatar
Never tried it but from everything I have read it does not work,be sure to let us know if it works.
Old May 18, 2010 | 11:23 PM
DustinRose's Avatar
try it, and find out
Old May 19, 2010 | 02:11 AM
hatchet_honda's Avatar
Originally Posted by bradennicely
anyone?
must use 90-93 teg knuckles. 94 + knuckles are too tall i believe.
Old May 19, 2010 | 02:13 AM
i used 99 gsr rear arms for my disc swap on my 91 civic hatch.and brake cables from the same year. worked awesome
silver_flash99
Oct 19, 2005 11:37 AM
crxhftosi
Jan 30, 2005 10:13 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
busychild
Sep 16, 2003 06:00 AM
SilverDc2
Sep 10, 2003 04:37 PM
