B18C DA Times?
I think DAs are lighter than the third gen as well. I think by 100 or 200 lbs. I have Weight List of most 90s hondas lying around somewhere.
its still not going to be that fast, if you're running a stock engine with street tires i'd say 15's, i think stock gsrs average about mid 15's, and its about 50 pounds difference between a 1994 ls and a 1990 ls
There 45lbs lighter. I have a JDM B18C swap that's stock running 163whp and ill be going to the tracks next month to do some runs. Ill let you know what i put down. But all my friends are at the mid 14s. Ill also poll up some of there time sheets if i can. Give me some time to do so OP.
Thats pretty good.
Im planning on keeping my LS Tranny since it has a stage 2 clutch already. Eventually I'll get a B16 Cable tranny.
Its going to be a clean, smooth, daily. Mainly 80 miles daily but it will be a nice little project. No runs at the track or anything. Im going to get it Bard. Hopefully this summer break Ill have it done before the laws change again
When I bought my clutch they told me it was only for the 90 and 91 tranny. Not even for the 92 and 93. So are you saying they're wrong and it fits different tranny? I want a 1st gen jdm b16 maybe with LSD if it's not a major price diff
Was that with a B16 tranny?
Thats pretty good.
Thats pretty good.
B16 is less torque and putting longer gears would slow it down even more wouldn't it? Yeah B16s are nice but IDK if it would be a nice enough upgrade from my current B18. Sure more power, but takes a crack at Torque. GSRs have come way down. The motor itself is almost just the same as the B16
Well I not going to lie I'm not sure on this but if it's a B series then I think it should work. The only thing I can think of that wouldn't would be if they had a different spline count on the older transmissions.
