is safe to stretch out tires????
i hv some new falken ziex ZE tires on my ls mech & i was doing some research on the width of the tires & how much it can stretch which was between 5.5-7 inches reconmended! but im planning on slapping some axis oldskool rims on it but the width on the axis's are 8 inches! is still safe to stretch the tires???? i need some opinion on this?????
im running stretched tires with no problem. i got falken ziex ze-512 and the size is 205-40-16 on a set of 16x8 wheels. the falken ze-512 are good tires to use if you want to get stretched IMO.
the 205/40/16 ziex ze-512 is approved for 7-8" wide wheels so techincally no you arent using "stretched" tires. OP, the 195/50/15 is approved for 5.5-7" wheel widths so stay within that range
yeah but the rims only comes in 15x8 so are thee others ties made for that fitment
10. Do not ask about "stretching" tires onto wheels that are too wide. All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
If you observe someone violating these rules, please use the button next to the post to report it, and let the forum moderators deal with it. Do not respond by committing a violation of your own.
^ taken from the wheel and tire forum rules.
