97 ls "b*tch pin" part number?
Old May 17, 2010 | 09:23 AM
ninty1civic's Avatar
Default 97 ls "b*tch pin" part number?
Need a part number for the bitch pin and c clip that holds it in..
Stupid dude at parts dealer couldnt find it...
Old May 17, 2010 | 10:23 AM
lsvtecwill's Avatar
Default Re: 97 ls "b*tch pin" part number?
I've always wondered it there was some way to just substitute it for a nut & bolt, but i'm usually thinking that as i'm trying to get it off...
Old May 17, 2010 | 12:52 PM
CivicTT's Avatar
pretty sure its 90751-S04-000
go here:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
#28
Old May 17, 2010 | 12:53 PM
CivicTT's Avatar
oh and the c clip is part number 54113-611-505
#1 on that site
Old May 23, 2010 | 07:52 PM
sweet got it
Old May 23, 2010 | 08:03 PM
racebum's Avatar
spending $25 on the correct matco tool to get that thing in and out was one of the biggest time savers i've ever had. that pin is insane without one.
Old May 23, 2010 | 08:28 PM
Rooftop voter's Avatar
Kinda funny you say bitch pin and everyone knows which pin your talking about!! Lol. **** that thing.
Old May 23, 2010 | 08:40 PM
i took one out on a dseires the other day with a 1/4 inch drive extension.. worked perfect..
Old May 27, 2010 | 11:08 PM
1deep_in_da4dr's Avatar
hey on g2ic.com they have a diy
Old May 30, 2010 | 07:16 PM
aut0tek's Avatar
Yep. I had the "bitch pin" problem twice. Once on my old DA, and once on my DC. Never again, thanks to a tap & die set. ;-)
Old May 30, 2010 | 08:30 PM
sc34dc4's Avatar
It's really not that hard to get out at all. I use a punch and a hammer. Comes right out with no problems every time. You can also buy the pin at a hardware store. It's just a compression pin.
Old May 30, 2010 | 09:05 PM
Jimmy's Avatar
Global Moderator
I'm sure you could and I believe i've seen it done before, but you will feel slack in the linkage. Nothing is going to fit it better than the pin.
A lot of people don't know this, but you can take the spare tire bolt out.. it kinda has a cone shaped end on it.. Use a 4lb hammer and I usually hit it 3-4 times and it's out. A lot of people have little qwerks and special things they use for certain things.. That's one of mine because it works perfect.
Old May 30, 2010 | 10:51 PM
da9leo's Avatar
I <3 DA's
can you link me to the tool please, i wanna make my life easier lol
Old May 31, 2010 | 12:36 AM
racebum's Avatar
http://www.matcotools.com/Catalog/to...&page=3&#51164
you can also call to see if a local truck is around and pick it up near by
Old May 31, 2010 | 10:44 AM
da9leo's Avatar
I <3 DA's
thanks for that, heading to my local truck in a bit
Old Jun 4, 2010 | 01:10 PM
strictly german's Avatar
I use a 1/4" short extension, and slip a deep socket over the bottom of it, one that is just wide enough to fit but not have any play. Then use the 4lb... works like a mini impact tool, and transfers the energy pretty good. comes right out.
Old Jun 4, 2010 | 04:58 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Pretty sure that the four bolts holding the a/c compressor on are what work wonders also.
I mean .. you have four of them, might as well make use of one anyways lol.
Old Jun 4, 2010 | 06:42 PM
Jimmy's Avatar
Global Moderator
Yeah man, that's what I meant to say.. I dunno what the hell i was thinking with the spare tire bolt. Lol.
94rs-turbo
May 14, 2011 10:59 PM
KGB_JDM
Appearance Build Threads
54
Jun 20, 2010 06:28 PM
no2unenolife
Oct 6, 2006 12:29 PM
DynastyRacer22
Mar 17, 2004 10:58 PM
