Ignition problems AGAIN
Old May 17, 2010 | 05:15 AM
type_r_teggy's Avatar
Default Ignition problems AGAIN
guys, i am having a very annoying problem, 4 the past 2yrs my car has been eating ignition modules, i have tried b new dizzy n still d same thing. now my cluster stopped workin only the battery light workin b4 u try to start if it does feel like starting nothin works no tach, speedo, fuel, temperature , nothing. only if u put on the headlights the cluster lights but thats about it. Now this problem is very recent, my questions are, r these problems connected n whats causing it? its the orginal engine n harness
Old May 17, 2010 | 06:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: Ignition problems AGAIN
The only thing that could connect them would be grounding, it is the only thing that is common between them otherwise the circuits are completely diff. other then they both have a switched power, [hot in run and start].
I would start by checking the main grounds, then harness grounds. 94
Old May 17, 2010 | 05:20 PM
goin by ah electrician tomorrow d car startin but when u giv it gas it jus goes dead n back fire then shuts down. Thanks
91akira
Feb 14, 2011 08:19 AM
siblues
Audio / Security / Video
10
Mar 11, 2010 11:55 AM
wes7side5o
Mar 22, 2007 05:07 PM
yellowEG
Oct 24, 2006 08:24 PM
Groove_D
Mar 21, 2005 10:44 AM
