transmission noise/grinding dilema
Old May 16, 2010 | 08:31 PM
tico's Avatar
Default transmission noise/grinding dilema
ok so about a month ago i changed out the oil in the trans and put fresh honda MTF in.. shifting got a little smoother especially at higher rpms... now within the last couple weeks i have noticed a deffinately noticible noise when gear...idk how to exactly explain it but it sounds like a bearing going out... it will happen ocasionaly in first after about3500rpm and alway in 2nd through 5th... but when i depress the clutch the noise goes away.. so what im trying to confirm without pulling my trans is if its a shaft bearing or my input shaft bearing.... cuz at idle and in neutral it sounds like the gear teeth are slapping or knocking into eachother ... so if anyone has had the same or similar problem and has corrected it let me know what was the problem..... thnk u guys
Old May 16, 2010 | 08:55 PM
DAMotorsports's Avatar
Default Re: transmission noise/grinding dilema
I had the same problem on my 98 HX, a lot of people said it was the clutch. i did a bit of research and found that the 96-00 SOHC trannys had a main input shaft bearing problem. I got a rebuild kit from autozone for about $300. when i split the tranny i found the bearing was falling apart. I have rebuilt 2 trannys for the same problem. the second one was so bad that the main shaft was moving in the tranny causing it to pop out of gear, the own was lucky and there was no gear damage but it sucked cleaning the thing out.
Old May 16, 2010 | 09:40 PM
tico's Avatar
so im just looking at a trans rebuil basically then correct??
Old May 16, 2010 | 10:47 PM
CubbyChowder's Avatar
im having the same problem right now and after a lot of searching i came to the conclusion that it was the input shaft bearing. I went to the dealer and bought the bearing as well as the seal and it cost me $45 total. I haven't replaced it yet because i haven't had time but from what i read this is all you need to fix it
TimelessLlama
Transmission & Drivetrain
Sep 24, 2018 01:59 PM
og seany b
Jul 17, 2010 07:03 PM
Jimster480
Feb 11, 2010 03:03 PM
1kleenef
Apr 13, 2008 11:12 AM
slowpokecivic
Sep 30, 2005 01:59 AM
